Heater core bypass
Originally Posted by McNab
I have to bypass the heater core in my 2001 Expedition 4.6L today. Can anyone tell me how to do this? Any pictures?
You have the quick clips attaching heater hoses to the HC, so it is not a worm hose clamp type deal. I looked around for a splice tube with those ends on it when my 97 HC was leaking and could not find one. You could always cut both hoses and add a typical hose splice between them. That was going to be my approach, but just did the core instead.
Heater Core By-Pass
On my '97 one engine heater hose connection is 5/8" and the other is 3/4". Disconnect the two at the engine and be prepared to catch/loose some coolant. Unless you have the special removal tool, you'll probably want to leave the other ends attached to the heater core.
Four hose clamps, two lengths of 5/8" and 3/4" heater hose, a 5/8" x 3/4" plastic adapter and some coolant/water and you'll be good to go.
