Wierd Noise After Shifting into second
Ok im not too familier with diagnosing sounds. under hard acceleration when it shifts into second the RPMs drop back to about 3100-3200 as normal then it hesitates for a second fall out about 100 rpm. This is also accompanied by a kinda raspy clicking ratling sound. im not sure what this is but any ideas on what it could be and how to fix?
Flex
Flex
would bad gas cause this? and will a fill up of 89 or 91 octane cure this? i normally get my gas at sheetz but the other day i was low when i left the house and went to the little coutry store to get some put 87 in it i think they have Citco im not sure though.? how do you adjust timing mine has one of thoes Spark pack things on it not a distributor?
ok i have uncovered another side of this problem, the noise is gone havent heard it anymore thx to a tank of 93(thx f151), but the "flatspot" "bog" whatever you wanna call it is still there, i did this tonight 4 times and it worked everytime. After it shifts into second right before it hits the "flat spot" if i flash the throttle (lift and gun it) no hesitation, no drop in rpm, just keeps on pulling so what am I tricking when i lift and gun it. something still not right. but its only in second. thats what i cant figure out i have tried to rev it to 3200 rpm to see if i hear a miss or something and got nothing, i also took it up to 3200 in 1st and nothing happened, i am baffeled.
**EDIT**also i dont know if i mentioned this during normal driving it does great its only does this at WOT***
