Oxygen Sensors
Originally Posted by mrjamjam
I changed mine at about 70K thinking it would help with mpg. It didn't help at all. Leave the front OEM in untill they go bad. The back two don't effect the tuning of the engine.
The Deal Is,
This is how it was explained to me by a very knowledgeable tech.
The O2's on most all newer OBDII are a heated O2. Its the heated part of it that gets weak. These new O2's need to run at a high temperature, higher than simply being bolted onto the exhaust pipe. When they get old since the heating element within is not so good any more, they make the engine run not as efficent. Most people who claim much better fuel economy after a new set is installed, live in colder northern climates. Where as most people who claim no real improvement live in warmer souther climates. Is this starting to make sense???
There were some people looking to save some $$$ who tried insulating the O2 with some folded up aluminum foil and tieing it with wire, They document a significat signal difference once insulated, yeilding better economy.
I myself live in NY and bought two Expeditions with 5.4's, I just purchased EIGHT O2's to do all on both vehicles, OOOUUCCCHHH!!!! $$$. Yes, I know that the rear ones only monitor the cats, and only need to be changed if they are bad= engine light. But ,I've had to change several bad ones on several Fords,so if I'm under the truck already why not.
My wifes truck I will not mess with, for fear of death. My truck however, I plan on doing myown insulator to test. I think that a cut peice or two of copper conduit will be better than aluminum foil.
I hope this was educational, ....Oh did I spell that word wrong??
lowflyingbird, I think I would find another tech.
The heaters only job is to heat the O2 sensor up faster. The temp. of the exhaust is more than enough to keep it hot. There was a time when O2 sensors had no heaters and worked just fine.
The only reason they have the heaters is to reduce the amount of time the engine spends in open loop. Open loop is when the PCM uses set parameters to control the fuel curve. When the O2 gets hot enough it starts sending a signal to the PCM, the PCM then makes adjustments to the fuel curve.
This is closed loop.
At 309,000 miles my truck has 2 of 4 original o2's. Anyhow this has been a topic here before. https://www.f150online.com/forums/sh...d.php?t=123409
