Stalling
My truck is an automatic but it stalls sometimes at low speeds taking tight turns like getting in and out of an parking space for example. What could be the problem?
Check the fuel pressure? Does it stall when you turn the wheel to lock? This will strain the power steering pump and load the motor, but it shouldn't stall.
Sounds like your Idle Air Control (IAC) valve needs to be removed and cleaned or replaced. Once removed, you can clean it with carb. cleaner.
sounds like idle air control valve..there is a needle in there that needs to move , its probably full of carbon etc... making it stick. some carb cleaner and a q-tip works well.
