F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   V8 Engines (https://www.f150online.com/forums/v8-engines-24/)
-   -   [PRETTY URGENT] Is this what's called a blown spark plug? (https://www.f150online.com/forums/v8-engines/265181-pretty-urgent-whats-called-blown-spark-plug.html)
Fordgirl18 Dec 19, 2006 02:02 AM
I drove from 0 to about 35MPH, revving it, at 3,500K RPM, and heard a POOF! like a tire blew out and then the engine started chugging like an old-time locomotive. I pulled over and noticed that the part under which the spark plugs are is loose and when I push it down, the chugging stops or lessens.
The spark plug nest in question is second from the front, passenger side (#7?)
I pulled it out, spark plug came out; the 'front' two (out of ten or so) turns of the thread were damaged.
jbrew Dec 19, 2006 02:14 AM
What year truck and what motor ?
Klitch Dec 19, 2006 02:18 AM
lol BREW whats that matter? the plug is out and bouncing around in your hands correct?
Fordgirl18 Dec 19, 2006 02:24 AM
F150 2002 4.6L V8
80k mi
tritonpwr Dec 19, 2006 02:31 AM
That would be #6, and it sounds like it may have just backed out on ya. That can happen if it wasn't tightened when it was installed for some reason.
If it blew, the COP would probably be dangling off the wire somewhere, and you'd be lucky to even find the plug.
Get a new plug and install it. If it spit the plug, you won't be able to tighten it. It will just spin in the hole.
SlammaJamma Dec 19, 2006 02:34 AM
Since it's a 4.6 I highly doubt its a blown plug.
Patman Dec 19, 2006 02:37 AM
x2:thumbsup:
jbrew Dec 19, 2006 02:39 AM
Hey I was here first and she could have a six - go harvest some tatertots Idaho :devil:
Could be bad news Fordgirl - There's all kinds of write-ups on this . Look up "Spark plug blow out" - Type it like that , but search the forum , there's three diff search areas here , make sure you search this forum for best results . Look to the right on the engines page - put the mouse over forums , choose search this forum from menus - it's on the right of the engines page .
You'll have to time-cert to replace the threads in the head if damaged, if it's just the plug that's damaged - then you lucked out and can fix yourself.
If not so lucky, some may do it while the head remains attached(wouldn't cost as much) but most won't fix it without pulling the head off the motor.
It derives from an improper plug change - although others have argued, boils down to if your plugs aren't installed following the correct procedure - this can happen.
Don't blame yourself totally if you installed, the manufacturer and dealerships as well have failed to do this properly in the past according to write ups within this forum. Ford supposedly didn't leave enough threads in the heads according to past complaints which doesn't make the task any easier.
Your going to have to take it in if the threads in the head are damaged and it can be very costly. I suggest you search this one out for more alternatives and learn what others have done in solving this same issue.
Klitch Dec 19, 2006 08:18 AM
hmm. oh snap?:lol:
actually there was a post made last week that has the link to the time cert site, which would be a little helpful because they have a video that demonstrates how the process works.
jbrew Dec 19, 2006 08:25 AM
hmm. oh snap?:lol:
Just pullin your leg Klitch :D
Fordgirl , keep us posted ,thanx.
Good Luck
csf150 Dec 19, 2006 08:52 AM
what in the world is a COP???? i read in a nother forum that some one preshure washed there engine and dried it out so how am i to clean my engine? thanks
jbrew Dec 19, 2006 09:11 AM
You have 97 - 97's didn't have the COP(coil over/on plug) systems unless you have a 5.4L.
Regardless, if stick a hose on your motor , you'll be back. Sensitive motors when it comes to moisture. Don't do it , unless you want headaches. You don't need too. Anyting that gets wet that should't may surge,short,ground - you don't want that to happen with these ignition systems. Been there done that . Do a search in the engines forum , read all about it.
putty knife , squirt bottle , don't get a wire or connecter wet.
MitchF150 Dec 19, 2006 10:11 AM
Hey Jbrew, how's it going?
This is funny, because I've got another thing I've done to my truck and have had no issues with that you disagree with!! ;)
I've washed my engine a couple of times in the 5 years I've owned it... It's been several years since the last washing, but it has not been as bad as this either...
https://www.f150online.com/galleries...1998-23169.jpg
When I finished up, it looked like this....
https://www.f150online.com/galleries...1998-23168.jpg
The only thing I will NOT do next time is apply the tire shine stuff... Sure, it looks great when it's fresh, but it attracts dust like a magnet! I've since wiped it down with a rag many times, but have not 'washed' it again.... It's due for a wash again, but I'm going to wait until summer.
All you have to do is cover the alt and use a pressure washer... Yes, a pressure washer! The trick is to keep the tip about 2 feet away from the engine and don't stop moving the wand... A PW at 2' is only a mist of water, but enough to rinse off the degreaser or whatever you spray on the engine to 'loosen' the grim... If you use a hose with a full stream of water on, you WILL drown an engine!! If you don't believe me, hold an open hose end over a bucket for a few seconds and see how much water collects... Do the same thing with a PW held at 2' away and you will see the huge different in volume of water in the bucket! :)
Just my experience with doing it....
Mitch
Oh, Forgirl18, all I can say for your plug is if it was the second from the front on the passenger side, I think that's the #2 plug??
Like was said above, try to thread in the plug and if it tightens down, you should be fine. If it spins in the socket, then you are SOL...
Good luck!
Mitch
BLUE20004X4 Dec 19, 2006 10:14 AM
Back to Fordgirl, as far as what # the plug is, it's #2. Ford has always done front to back 1-4 on pass side, then 5-8 on driver side. Just a little info, doubt it helps or matters in this case unless you have to buy a new C.O.P or injector. Hope you figure out the problem, very important not to strip the threads as someone has done here in the past it seems.
jbrew Dec 19, 2006 10:31 AM
Hey triton , Dannggg , you F'ed up and I didn't catch it , that is #2 -LMAO
who's your editor? :D
