water temp gauge
anyone have a good place to install a water temp sending unit.1/8 pipe thread electric on a 2002 5.4 supercrew.thanks
i installed mine by cutting into the heater hose that is on the top of the PS of the engine, using a T fitting, you will have to ground the sensor using this method, this gives me the temp even before the themostat opens so i know what temp the engine is running at all times, good luck
