F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   V8 Engines (https://www.f150online.com/forums/v8-engines-24/)
-   -   what's dohc or sohc (https://www.f150online.com/forums/v8-engines/206086-whats-dohc-sohc.html)
mountnman Jul 28, 2005 04:04 PM
thanks
thanks
Bluegrass Jul 28, 2005 04:17 PM
Since there are valves to be operated on each head, SOHC and
DOHC means one or two cams each side. (single/double). Your's is SOHC.
Do you have a CEL lite on? Is there any codes stored?
If the plugs have not been changed, it's time.
Do cleaning of the EGR passages.
May need new OX sensors.
These are all normal maintaince items that should be changed with the age and mileage of the motor even if there are no running problems..
Faster150 Jul 28, 2005 04:47 PM
Safe Orange Hand Cleaner and Dangerous Orange Hand Cleaner :-p
Miles73003 Jul 28, 2005 04:52 PM
More simply stated, it means Single Over Head Cam (SOHC) or Dual Over Head Cam (DOHC). Goes hand in hand with - 16 valve motor=SOHC and 24 valve motor=DOHC. As far as MSD goes, it is a good brand but I personally would just stick to OEM especially with a stock truck with 100000+ miles. You're not going to notice any performance gain going with an aftermarket performance ignition system more than likely. Make sure you read up on some posts, books, guides, etc. or get a buddy to help before going under the hood and yanking at things...you can screw some stuff up if you aren't too sure with what you are doing. Just make sure you know what things are and where they go. Good Luck :thumbsup:
01vert Jul 29, 2005 01:36 AM
ahhh, that would be 16 valve or 32 valve........24 would be a three valve engine which is a SOHC.
umachme Jul 29, 2005 01:28 PM
Dohc
Originally Posted by mountnman
I'm looking to tune up my 98 f150 4.6L 4x4 and would like to replace the plugs, wires, os's, coil and whatever else anyone can suggest. It has 104,000 on it now and I purchased it new. I was looking on ebay for some stuff and found msd wires and 4 tower coil for sohc and dohc could you tell me what that is and how to know what I have. Also if msd is a good brand to go with. Or should I stick to oem, and best place to purchase my parts other than the dealership exxxxpppeeennnsssiiivvvee. I searched through the archives and found some good reading just would like to get some more input. The reason for this is the truck started chugging the other night once I got up to 55 ( didn't notice it while it was idleing) so figured it's time for a tune up. All help is Appreciated!!!!!
:beers:
IF YOU DONT KNOW THE DIFFERENCE BETWEEN DOHC AND SOHC DONT BOTHER TRYING TO FIX YOUR OWN VEHICLE.....
Faster150 Jul 29, 2005 02:32 PM
nicely put :-p :banana:
01vert Jul 30, 2005 03:44 AM
Yeah that was nice.....
adrianspeeder Jul 31, 2005 12:53 PM
What kind of bad attitude is that??? Not cool.
Why did the origional post get edited?
Faster150 Jul 31, 2005 01:52 PM
i guess we made em feel unwelcome or dumb...
