MERGED: ULTRA FILTER, lifetime direct replacement washable oil filter
Ultra Filter - any good?
I can't help but see the ad everytime I come to this forum to the left on the Ultra Filter. After reading the blurb from Laguna Speed Shop, it looks enticing. Anybody using one of these yet and any good or bad experiences with it? I'm thinking of switching to synthetic oil and looking at my options for a decent oil filter.
Oil filters are rated by their Beta ratio. That is a test whereby the filter is exposed to a known quantity of glass particles of known size. The Beta ratio is the amount of particulate filtered. The website for this filter makes some ridiculous and missleading claims. They claim a paper filter element with a by-pass valve will open at 11-12 lbs. That's kinda correct but no cigar. It opens at a 11-12 lbs differential of pressure, not just 11-12 lbs of pressure. To use a filter in any engine that has no by-pass is asking for trouble. What happens if your engine has a problem like a leaky head gasket and sludge starts to build? Now what? And per their website, it filters at 35 microns. A particle of 40 microns will damage an engine. As far as the paper filters not filtering as good- pure BS. Most of the OCI filters will hit 10 microns at 90% single pass. Maybe has value on a Baja engine or a dirt race engine but it isn't something I would use. Here is their info
http://www.ultraoilfilters.com/uoff/...sed;guest=1710
For those of you that are looking for good filtration and want to spend the money, a by-pass filter can be a good option. The FS 2500, Oilguard, and Amsoil unit will filter to 3 microns which far exceeds this cleanable thing. Most gas engines don't require this level of filtration even for extended oil changes. Not that the filters standard filters are that good but rather, the oils used for extended changes are that good in keeping the dirt suspended and breaking it up into small harmless debris. The engines of today are also extremely clean by comparison to engines of just 10 years ago. It ain't the same old ball game.
Any tried one of these things yet?
https://www.f150online.com/forums/sh...d.php?t=203571
Posted the VERY SAME DAY... then RP moved it off to Engines..
Average gains 5-6hp?? 1-2MPG increase???? From an oil filter? I don't think so. If I could gain 2 MPG by spinning on a new oil filter and save about $7 of gas a week then I think everyone here would have one of these. Also, it says "it has no bypass because paper filters usually only work 10-20% of the time, and unless you are idling the bypass is open".......yeah, maybe if it has been 20,000 miles since the last change......What a load of crap. I'd rather not run an oil filter than run this POS. Companies that claim this kind of stuff about their products with no info to back it up should be shut down.
I can buy 25 or more FL-820S filters for that cost and I don't have to clean them. Just throw them away. I'll stick with the throw aways. I can't imagine how hard it would be to clean those things. Of course I am sure they will sell me some kind of cleaning kit.
Obviously they are selling well. They have a $60 price drop.
