F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   V8 Engines (https://www.f150online.com/forums/v8-engines-24/)
-   -   98 won't start - things I've tried... (https://www.f150online.com/forums/v8-engines/198003-98-wont-start-things-ive-tried.html)
BKFZ1 May 18, 2005 03:39 AM
Hey kids, newbie to the board... :help:
My 98 F150 4.2L (115,000 miles) will not start, and gave no signs it was about to fail. Turned the key and got somewhat of a single 'cough' and nothing; subsequent tries would result in just a 'click'.
Here is a list of things I've tried along with comments & questions:
-new battery (checked/verified full power)
-starter motor checked (passed)
if the starter passed testing, was the solenoid (attached to the starter motor) checked along with it?
-alternator checked (passed putting out 13-14 amps)
-starter relay on firewall replaced (not needed; I learned from this board how to test by jumping. Also ran a jumper from the positive battery terminal to the relay to test)
-replaced fuel filter.
-checked every fuse in the truck (but I don't know how to test a 'fuse/relay')
-tried starting with the (automatic) transmission in neutral.
All of these things resulted in the same 'single cough', then nothing.
One strange note: after replacing the fuel filter, it actually turned over several times, then stopped. And didn't do that any other time.
Any connection I can see or have uncovered do not seem to have any corrosion, but I know corrosion could be an issue somewhere I can't see.
Any suggestions a novice mechanic can try next?
Replies or not, this board is one heck-of-a resource :bows:
Thanks everybody!
-BKFZ1
BKFZ1 May 18, 2005 03:45 AM
ingition switch
I pulled the ignition switch and tested. The pin moves as it should along with the 'spring loaded' start position of the pin. Continuity was tested in each position - all passed.
And the strange thing happened again: it turned over a few times, one cough, then nothing.
-BK
