Oil filter relocation
I would like to relocate the oil filter on Da Ghost. Where can I find this kit/part? Is it part of a dry sump system? how difficult is it to install?
Oil Filter Relocation
Dear perceysledge Go to "Amsoil.com" they have kits for oil filter relocations.
i forgot ur second question, yes its very easy to do, you get an adaptor plate that fits on ur engine where ur reg oil filter mounts, it screws on just like an oil filter, it has 2 hoses that lead outta it that go to another oil filter base, with mounting brackets, most use a bigger, higher capasity oil filter, most use the old style Ford filter like the Fram PH8A, NAPA 1515, they also make dual filters one being a bypass, when you route the hoses just keep them away from the fan blade, and the exhaust manifold, use plenty of tie raps to hold the hoses and they will last forever.
Re: Oil filter relocation
Originally posted by percysledge I would like to relocate the oil filter on Da Ghost. Where can I find this kit/part? Is it part of a dry sump system? how difficult is it to install? http://www.perma-cool.com/Catalog/Ca...tml#supermount http://www.perma-cool.com/Catalog/CatImages/PG31-R2.gif The permacool system will require you to use a FL-1 sized filter(or fram PH8A) This is the old Ford truck filter that is about 1 quart in capacity!! The system that moto is describing above includes a by-pass filter as part of the relocation. |
You can also go to a junkyard and take the factory remote system from an earlier F-150 or Expy. The lines leaked on my '97 5.4 so I took one off a truck at the junkyard for $15.00. No leaks.
Re: Re: Oil filter relocation
Originally posted by msparks The system that moto is describing above includes a by-pass filter as part of the relocation. https://www.amsoil.com/bypassfilters...tionguide.aspx |
I just looked under my truck for a suitable location for the new filter, but I don't see a really good place. Any suggestions on locations? With that large a filter I don't want it hanging down too far. Any pics of installations on a heritage F150?
I had a perma cool relocation kit on my truck first from Jegg`s, it leaked real bad the hoses just would not tighten enough ,bad hose clamps. So I bought a TD relocation kit from Sumitt Racing ,the hoses were threaded with brass ends, sealed up like it should have on the permacool kit. Alot nicer kit for around $50.00.
The perma cool kit you had to cut the hoses to fit where you wanted plus use hose clamps too. Not on the TD`s kit. Lariat#1 :D :D :D |
This may be a stupid question, but maybe I'm missing something?
I've never heard of re-locating an oil filter. The only plausible reason I could think to do so on these trucks is maybe to place the filter vertically so one could fill it with oil before installing? Is this what you guys are talking about? |
It also allows easier access to the filter itself, that is, if you mount it somewhere where it will be easily accessed.
My 98 has the factory relocation kit and the filter is in front of the left front tire behind the bumper. Very easy to get to but also protected. My brother in law has the filter direct on the block and it is a PITA to get to. |
you can relocate a oil filter on anything
most race cars and dragsters have them mounted somewhere on the frame for e-z access remember to add x-tra oil for the lines and if the new filter is bigger than the replacement i wish i could move the one on my diesel :( ...zap! |
