F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   V8 Engines (https://www.f150online.com/forums/v8-engines-24/)
-   -   Help! I'm losing oil from the filter hose (https://www.f150online.com/forums/v8-engines/181502-help-im-losing-oil-filter-hose.html)
primecut36 Jan 11, 2005 07:29 PM
I've got a '98 F150 4x4 w/ the remote mounted oil filter. Recently one of the hoses started leaking on the filter end. The dealer wants $185 for replacement hoses ! :bandito: A respected mechanic told me I could cut the crimping off and use a A/C clamp. Has anyone had this same problem? Anyone clamped the hose successfully? TIA.
Bluegrass Jan 11, 2005 08:21 PM
It may or maynot be a good alternative but make dam sure you do it good because if the hose flys off, you have no oil pressure left and the result will be a lot more than $180.
srfd44 Jan 12, 2005 08:51 AM
I would go to a hydraulic hose shop where they make custom hoses and let them make up a set. Should be cheaper and better in the long run. Make sure you take the hose off for them to match up.
Good Luck
