F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   V8 Engines (https://www.f150online.com/forums/v8-engines-24/)
-   -   skipping at low rpm's (https://www.f150online.com/forums/v8-engines/142723-skipping-low-rpms.html)
MYOST79 Jan 14, 2004 09:42 AM
kind of confused on this one. Im having what seems like a engine miss at low rpm's wich is more noticeable when going up hills. so far ive changed the plugs and wires, and also checked the clutch for slipping. the truck is a 97 with 4.2L 5 speed. It does this in every gear accept 1st and 3rd. I know there maybe several fixes with this one but don't know where to start. thanks:confused:
temp1 Jan 14, 2004 09:48 AM
Is your check engine light coming on?
Take it to Autozone and see if they can pull some trouble codes. I hear they do it for free.
MYOST79 Jan 14, 2004 10:00 AM
temp1, the check engine light is not on. but will try that, any other suggestions.
temp1 Jan 14, 2004 10:11 AM
If it does it only in certain gears then it seems to be related to the transmission somehow. Other than that, Im clueless.
Do you have a manual or automatic transmission.
