squeaking 4.6L
hey all,
i've got a 2002 F150 4.6L with almost 22,000 miles. whenever i start my truck, i hear a squealing coming from the front, which stops once i begin driving. this only happens when it is either cold outside, or it has rained the night before. it only lasts for a minute or less, but what could the problem be? my guess is maybe a bad pulley bearing, or the belt it bad. any help would be appreciated. thanks in advance. |
Get a Gatorback belt. It will be the belt slipping some. Check everything with the belt off and if you feel a rough bearing you also may have found the culprit.
My powersteering causes that when using anything but a gatorbak. tom |
