F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   V8 Engines (https://www.f150online.com/forums/v8-engines-24/)
-   -   Turns over...won't start...HELP! (https://www.f150online.com/forums/v8-engines/117452-turns-over-wont-start-help.html)
Rotties150 May 24, 2003 11:16 PM
I'm in trouble here folks
I was putting in a power line for an amplifier this afternoon. Took out the battery and holder...ran the line and put the battery back in. Try to start it and it sounds like it's not getting any gas...turns over just fine...just doesn't start
Two thoughts come to mind.
First...While looking for a place to run the line thru the firewall, I was playing with the Power Control Module. Didn't disconnect it, just jiggled it around a bit. Also the bolt holding it in just spins...stripped(?) I suspect? If any connections there are loose, then there's a problem...but how do I tell?
Second...in the cab on the passenger side where I fished the wire out, and I'm near the fuel pump reset button. Could I have done something to that to have caused the gas not to pump?
I'm at a loss here and it's Memorial Day weekend and no one is going to be open to repair a dead Ford. And I gotta get my wheels back.
Any help would be GREATLY appreciated...Scott
:confused:
:bows:
Rotties150 May 25, 2003 10:32 AM
:banana:
Never mind...I found the problem.
I must have accidently hit the fuel shut-off stwitch while digging around moving things around under the passenger side kick plate. A quick reset and it started right up.
Time to relax and go have some :beers:
