Misfiring after plugwire changr
I have a 2002 with the 4.2 and 112,000 miles and I just bought the truck so I'm doing a tune up, I replaced spark plugs a few weeks ago, and did plug wires yesterday. Soon as I finished I drove down the road (maybe 2 miles) and it started mis firing. I didn't cross any wires as I swapped one wire at a time to make sure. So a mechanic buddy of mine told me it might be the ignition coil pack, and I replaced it and same issue it's misifiring at idle and almost imedimmedia after start I have the pack set up as
Cab
3-4
2-6
1-5
Fan
Is there anything else I can check? I checked all spark plugs last night and 2 of them was cold and covered in gas and the other 4 was warm that's why we thought the coil pack.
Cab
3-4
2-6
1-5
Fan
LOL I didn't see it until I halfway started to click reply... until I re-read it and saw that was the way you saw the coil pack...
Just double check your firing order and coil pack order is like this:
It's really easy to mess this up... trust me, I know.
Last edited by ManualF150; 10-14-2018 at 02:51 PM. Reason: Didn't read too carefully... but maybe the plug wires are going to the wrong cylinders...
You can order Motorcraft wires from Rock Auto at less than half the price Ford wants for them. Duralast wires are junk.
You may have a couple defective spark plugs.
MOTORCRAFT WR6110 {#3L3Z12259AB, WR6080} $37.79 Wire Set
MOTORCRAFT SP504 {#AGSF34FM, AGSF34FMF4, AGSF34FMF6} Finewire Platinum Gap: .054 $3.18 Spark Plugs
MOTORCRAFT DG532 {#5F2Z12029AD} $66.79 Coil Pack
When I owned a 97 F150 with the 4.2 V6, I installed Autolite plugs. That engine sneezed, wheezed, jumped, misfired, basically ran like FECES!
Also, buy MC wires as well. And check your plug wire connections to the coil like MF150 suggests. One more thing that I have had happen, check each plugs porcelain. There could be a hairline crack in one or more of them. Did you use anti-seize on the threads? If you accidentally got some on the electrodes this can cause a misfire.
