Vacuum hose diagram for 2001 F150 4.2L V6
Hello everyone, does anyone have, or know where I can find, the vacuum hose diagram for the 2001 F150 4.2L V6? I've looked everywhere, but can't seem to find one more my truck. I want to make sure I check ALL the vacuum hoses on my truck, because I'm getting a P0171 that I simply can't find. - I suspect its thrown because of a possible valve train issue I'm experiencing, but I want to rule out the vacuum leak issue before I open the upper end of the engine.
Thank you,
Calixto
Thank you,
Calixto
Nope. It's pretty simple.
But simple is only what you can "see". Tracing some of these lines is a complete pain in the you know what...
Best way to find leaks is using an UNLIT (yes -- UNLIT) propane torch and tracing the lines out with it. Any cracks/openings will suck in the propane and the engine will try to burn it causing a very noticeable change in engine RPM and sound.
