MAP Sensor Test Procedure 2014 Ecoboost
Old 04-07-2018, 07:57 AM
smhamilt's Avatar
2014 F150 XLT Ecoboost.
I have P0172. I purchased a OBD2 diag wifi and got it all hooked up. I see 3 MAP sensors but only 1 readout for MAP on the OBD2.
I need to clean/test the MAP sensors. Can someone tell me what they are supposed to read (Hz or variable volts at the signal out/signal ground wires).
Any help is appreciated.
Old 04-07-2018, 08:54 AM
I would start by cleaning the MAP sensor. That's what most people do to clear up that code. Then go from there.
Old 04-09-2018, 06:48 AM
smhamilt's Avatar
Cleaned all 3 MAP sensors. And changed plugs. Long term fuel trim is still -25% on bank 1. And bank 2 is very low also -10%-15%. Long term FT stays around zero when rpm’s increase. Short term fuel trim is near 0. So looks normal when rpms are up. LT fuel trim shows rich -25 at idle. Any other suggestions.
Where is the intake air temp sensor? And how do I actually test the MAP sensors? Also, emissions test report says O2 heater.
Old 04-09-2018, 09:34 AM
Wookie's Avatar
The intake air sensor is in the air intake pipe directly downstream from the filter. It looks almost like a MAF housing but it's not.
Old 04-10-2018, 10:54 AM
smhamilt's Avatar
I have part number CV2A-9F479-AA on that sensor. (Immediately downstream of filter) Says it’s a MAP sensor. Does it measure intake air temp too?
Old 04-11-2018, 03:19 PM
Wookie's Avatar
Yes, it's a little bit different on the 2011s though. For the 2012+ that part number with a -A is on the air cleaner, -B on the intercooler outlet tube and -- on the intake manifold. They are all a combination pressure and temp sensor.
Old 04-11-2018, 03:38 PM
smhamilt's Avatar
Can you tell me exactly how to test it with a DVM. I have yellow/brn (ground) yellow/ green (5V power I think), grey/blue and green/brown wires. Not exactly sure exactly how to test it.
Quick Reply: MAP Sensor Test Procedure 2014 Ecoboost
