Coolant Leak
Coolant Leak
I have a question. I have a 2014 f150 supercrew 3.5 ecoboost with 70k miles. Recently I have had to add coolant regularly. I looked and thought it was coming from the thermostat. Now after further inspection I saw some fluid on the top center of the engine. Could that be due to a head gasket? No milky oil, no antifreeze smell exhaust or white smoke. Is there anything else that could be causing this?
That doesn't sound like a head gasket if it's in the very center on top of the intake manifold. I suspect that it's actually spraying from somewhere to get there. Look at your heater hoses where they go into the firewall. I can't remember if there's another hose that runs across the top of the engine but check around for one coming from the expansion tank.
After a more in depth inspection, the fluid on top was not the coolant. Found out it is leaking from my drivers side turbo. I am planning on fixing it myself. I think it is only one of the connections. Would it be better to just remove it and replace all gasket? Glad it is not the head gasket.
