2013 Ecoboost overheating towing up hills
#31
The info from the owners manual actually kinda sums up the condition but my confusion is still there. Why has this only happened SINCE I had the PCM updated? As mentioned before this truck has pulled the same trailer in the same conditions before without a gauge moving let alone to the overheat level. It seems to me that maybe the temp levels allowed before the warnings come on have been considerably lowered with this update. I would think an engineer should be able to give me this information. If that's the case then at least I can rest a little easier the next time I see it. On the other hand kinda makes giving a 1/2 ton truck an 11000 + "towing capacity" seem STUPIDer than I've always thought since I am a long ways from my trucks advertised capability.
#32
I'm guessing that the PCM update was done to reduce the chance of overheating danger to the truck while towing. Note the power reduction doesn't stop you from pulling the load, it just makes you do it "more gently". And, why the Ford techs don't know about this is also a mystery. Probably, they were never educated.
I think, combining what my manual says with the information you're getting from the dealership, that my opinion is correct. The truck's powertrain (both the engine and transmission) CAN get quite hot when under heavy load in high ambient temperature conditions. That can't be good for long life.
- Jack
#33
#34
I guess the bottom line is I'm afraid of this causing more problems than just the truck "possibly" overheating....like getting run over by a semi as your trying to pull your OVERLY cautious pickup with trailer over on a narrow mountain pass. Guess according to these engineers that's not as important as their little engine. It actually makes sense when the unit is pushed closer to the capacity limits they advertise but again, I'm not close. The thing that really pisses me off is the fact that I have considered myself one of the biggest Eco fans out there (I absolutely love my truck and up to now I was extremely confident in its abilities to bully those big V8's in the hills) but now I'm unsure at best.
#35
http://www.tascaparts.com/oe-ford/9l8z6g004e
#36
Put it into test mode next time you're going to pull a big hill. That will read out the exact coolant temp and it's free. There's a thing called a Scangauge that plugs into your OBDII port and puts this info a digital form. There's also Bluetooth adapters that turn your phone into digital gauges. All of these will give you peace of mind about what's going on.
However, since all of this started after a software not a hardware change I highly suspect the new program changed the warning threshold.
#37
#38
#40
Crystal
#41
Nothing other than a PCM update. Based on the number of similar complaints I see and the canned response I would bet money that nothing will be done other than a PCM update and hope that you are towing when ambient temperatures are lower. I will say that my truck performed better and "as advertised" when ambient temperatures are lower. I too have lost the confidence in our truck towing when the conditions are hotter. I should not have to plan or worry about weather conditions when towing but that seems to be a reality for this engine. I am moving on as I continue to see the same response time after time.
Good luck with your dealer and Ford's customer service team as I believe their hands are tied. I have been down that road and while I believe they truly tried to help; they were not able to provide any solutions other than what you will read in this thread. I appreciated their attempts but it was a complete waste of time. Let us know if you get any resolution that is different that what we have been reporting on this thread.
#42
I agree completely colbray. Its not the tech / dealer / customer service teams. I just wish I would have stayed with my old saying "if it ain't broke don't fix it" and not done an update and my betting money says I wouldn't have had this issue. If only someone would confirm this for me....at least I'd feel better putting the hammer down pulling the mountains again.
#45
I have talked to my dealer and they have given me the same story, No CEL mean no issue and even after plugging in the find no issue.
My truck has 81,000 Miles. This is my second eco boost F150, the first was a 2013 as well and would easily tow double the load with no issue regardless of conditions outside.
I went out of town again this last weekend and towed about a 5500 LB boat to lake powell. this time in the middle of the night so cool conditions and it would do everything i required of it with no over heating.
It is quite frustrating that I cant tow 1/2 of the rated capacity without over heat issues during the day.
