2004 4.6 heritage coolant leak!?
Old Jun 14, 2014 | 04:05 PM
CGMACIAS's Avatar
Originally Posted by jgger
The p0113 is intake air temp circuit high.
Check the intake tube between the air cleaner and the throttle body to make sure everything is tight. An air leak there will cause the lean codes you are getting. The IAT is also located in that tube, if it isn't seated or not there then you may have found your issue. Check the electrical connector to make sure it is clean and making good contact. I believe the IAT is located on the bottom of the intake tube. Also check the grommet where the wires go into the air cleaner box (the part that comes off when you change the air filter) to be sure it is seated.
Are you getting any misfire codes?
I checked the electrical connector and it does look pretty dirty but is connected properly, the grommet looks snug and clean, and the air filter is new...I rescanned just to make sure I got the codes right... and the code P0701 is now pending and codes read are P0113 and P0704 not sure if it matters wether the code is read or pending...
Old Jun 14, 2014 | 05:11 PM
P0701 and P0704? Those are transmission codes...................
Are you looking at the IAT or the MAF sensor?
Old Jun 14, 2014 | 05:20 PM
CGMACIAS's Avatar
**** ment P0171 0174
Old Jun 14, 2014 | 06:29 PM
Both banks lean start looking for vacuum leaks
threads merged one thread per subject please
Old Jun 14, 2014 | 09:51 PM
CGMACIAS's Avatar
Last question is...
Would the truck make a 10 hour round trip drive with these codes??
Old Jun 14, 2014 | 11:26 PM
I wouldn't do it.
Old Jun 15, 2014 | 07:14 PM
CGMACIAS's Avatar
Let The Misfire codes reign in...
Changed mass airflow sensor and IAT Sensor that got rid of the P0113 but not P0171 or P0174...Now unlike before it also reads a couple of misfire codes...One stating its misfiring under 1000 revs P0316 and one misfire on cylinder 3 P0303
Old Jun 15, 2014 | 10:24 PM
Now you need to look deeper and find that vacuum leak. It might be the isolator bolts on the plenum.
Old Jun 18, 2014 | 11:39 AM
CGMACIAS's Avatar
I was changing the throttle body gaskets when i Noticed there was oil in the throttle body...does it belong there? i was also wondering if there really is a vacuum leak or its just the pletnum getting excess air from the throttle body causing it to whistle?
Old Jun 18, 2014 | 05:56 PM
Large vacuum leak can whistle.
oil film *is normal* on PCV system due to positive crankcase pressure
Old Jun 20, 2014 | 03:32 PM
CGMACIAS's Avatar
So after changing the gasket on the throttle body, i re scanned after 25 starts and only code that shows now is p0174...so im guessing it was multiple problems leading to the same code?
Old Jun 20, 2014 | 08:38 PM
You still have a lean code. It's not completely fixed yet. Lean on one side only can be an exhaust leak before the O2.
Old Jun 22, 2014 | 11:31 AM
CGMACIAS's Avatar
That did it! After 2 weeks of bi polar codes read... Trucks back to normal! no sputter,no hesitation, and best of all the service engine light just went away after fixing the exhaust leak, Thanks!
