Ecoboost mileage doesn't add up
Old Jan 14, 2014 | 12:51 PM
  #46
johndeerefarmer's Avatar
Originally Posted by papa tiger
The 15/16 2.7L sequential turbo Nano motor is to get 28 mpg in the F150. Ford reaches for it to put the Ford fleet near the 35 MPG across the fleet target the EPA has set.
But it also uses start/stop technology and active shutters in the grill (not sure if all the new engines do or just it).
As far as EPA tests for the eco, yes it will get into boost unless you drive with an egg under your foot and on flat land. More boost= more power= more fuel burned.
Old Feb 13, 2014 | 01:08 PM
  #47
J-150's Avatar
The 3.5 has a different tune, even without the turbos spinning.
More HP = more fuel used. Period.
Even 2 of the same engine can get different efficiency scores. Case in point, the 2.0 in the Escort and early Focus vs the Mazda 3 cousin using the same engine (Mazda having a more aggressive tune)
