mchartmann |
04-15-2013 02:59 AM |
1999 Ford f150 v6 miss on slight acceleration
I have a 1999 Ford all stock F150 4.2 v6 with 165k miles that idles perfect but under light load misses and shakes but under heavier throttle does not miss. No codes, replaced with motorcraft plugs and wires, air and fuel filter, coil pack, tps, cleaned maf, replaced dpfe, pcv, replaced decomposed pcv hose. I used to be a master tech for Ford but I was not a drivability tech. I ohm the new motorcraft wires and they ranged from 9.2k to 11.8k ohms. Trans works perfect and fluid clean I do not suspect shudder. My next suspect is FPR or possible lean condition on one or more injectors. and goes away when computer commands more injector opening time under heavier throttle. Any thoughts what else to look at? Update, Installed new fpr and new ground for engine cleaned IAC, EGR, I did notice misfire gets worse as engine gets warmer. Still no codes
