Cat-Back Exhaust
Old Oct 11, 2000 | 02:18 PM
Hotshot's Avatar
Question Cat-Back Exhaust
This is probablly a stupid question but what is that difference between a cat-back exhaust and any other exhaust such as dual exhaust? And what would be best for my truck? I hear the ravin is good. But I like the look of the gibson super truck exhaust. Any help would be appreciated.
2001 f-150 v-6 5spd
sport package, pendaliner, bug guard
[This message has been edited by Hotshot (edited 10-11-2000).]
Old Oct 11, 2000 | 07:23 PM
max mitchell's Avatar
Cool
"Cat-Back" refers to a system that bolts on behind the catalytic convertors, and includes a muffler, intermediate pipe, and rear or side pipe. It generally comes in a kit specifically designed for each application, and includes mandrel bent pipe. Other systems would be fabricated on site at a muffler shop, and may or may not be mandrel bent or be properly engineered. The dual exhaust could be "true, separate pipe" or dual outlets after the muffler (your choice). There are people here with every system available to help. You might start by deciding what materials (aluminized or stainless), exit location, single or dual, desired sound, and tips. Check out some exhaust web-sites and members opinions and then you will have a better chance of finding what you like. Good Luck !
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification, Superchip,
Dynomax ultra-flow welded 3" cat-back,
3" exit Y-pipe, Hellwig rear anti-sway bar,
Rancho RS9000s.
Old Oct 12, 2000 | 12:44 AM
bomber's Avatar
Banned
Post
when i had my exhaust redone what i had the muffler shop do was. they cut off the stock muffler,kepp the y pipe on "which comes from the cats" they then put my flowmaster40 series single in dual out on.. then the guy bent 2 pipes that went over my axle and out the rear with 3.5 inch beveled chrome tips. it sounds great and helped tons. no loss in low end. i actually have better acceleration now and i also have better gas mileage.
hope this helps.
chris
