Digital Odometer
I have read there is a hidden digital tachometer within the digital odometer, now here is my question what other little things are hidden with the digital odometer could you please tell me? pretty please
To view it you must press and hold the reset button while you start your truck. After started continue holding until "test" pops in the digital area. There are many features in there, so what you have to do is press the reset button to file through until it reads "tach0000". It will read some value if you start your truck and will read 0000 if you just have the ignition in the run position with the truck off. Hope that explains it good enough. If not, ask me to explain again.
2000 F150 XL Wedgewood Blue. Eclipse flip down CD player, Eclipse point source door speakers. Rockford Fosgate 8' truck box speakers. Fosgate 160x4 punch AMP. Power and appearance mods to come.
Sport, It worked on my truck with the digital odometer and I have a 99' Ford F-150 XL Sport So it should work on yours as long as you have a digital odometer!
Cool huh?
Cool huh?
I've been trying to find that out myself. I believe that the one marked fuel, represents how many gals of gas are int the tank, with the last number representing a tenth. With a full tank mine will read about 243. As for the rest of the readings still haven't got a clue, but checking into it.
2000 XL Flareside
V6, 5 Speed, 3.55
K&N Air Filter
2000 XL Flareside
V6, 5 Speed, 3.55
K&N Air Filter
I've researched into that option myself, but no success yet. If anyone finds a way I'd like to know.
Also would like to know the where it redlines, and stck setting for rev limiter, looked at the xlt's tach goes o 6000 rpms, but no redline markings..
2000 XL Flareside
V6, 5 Speed, 3.55
K&N Air Filter
2000 XL Flareside
V6, 5 Speed, 3.55
K&N Air Filter
Hay guys, it took me some time to dig out of the moth ***** but I found a thread that might be able to help yall. I pulled up on the "engines" board. There is also a link that might be able to help in the thread. Happy reading.
Hey C. Mathews,
I was thinking that the number it shows for fuel represents the amount of miles left to travel with the amount of gas you have left.
Another cool thing that I'm sure some of you have probably noticed is that it has a digital speedometer too! This is cool for me because my MPH gauge was thrown off when I installed the Indiglo's. But now I can set it just right!
