Towing with Manual Transmission
I have a 1999 F150 4.2, manual transmission with a 3.08 Axle. The owner's manual rates max. towing at 2500lbs. The Automatic with a 3.31 Axle is rated at 4800lbs. That's a big difference. I always presumed a manual transmission could handle more weight than a Automatic. Any Thoughts?
Apparently the input shaft on the M5OD transmission is the weak link and the reason for the significantly lesser towing amount. I had a 97' F150 with the M5OD and I towed some decent loads with it a few times. However, if you're looking to *often* tow more then the recommended weight, I'd either look for a more capable truck, upgrade your gears from 3.08, or accept when parts wear out\break and fix accordingly.
Also, if you search "M5OD" and "input shaft" you will see a lot more results and opinions about this subject. Welcome to the site!
