Lean Codes P0171 & p0174 / p1131 & p1151
did that already too like 6-8 months ago here is a list of stuff replaced
isolater bolts and gaskets ,cats , have new spark plug wire and spark plugs butmight need change have but about 20,000 or more on spark plugs. pcv tube and o rings on the valve covers.
only things i havent changed are 02 sensors since i purchased and blew my cats like 6-8 months ago before changed and fixed the isolater bolts and gaskets. and recently i had a leak in the ac vac line but fixed and replaced that unless it has a another hole but my ac is working when there was ahole in the ac line no ac.
same codes p1131,1151,p0171,p0174
1998 f150 300,000 starts great untill somthing opens up (sounds like themstat in water pump type click) and runs great untill you will get to red light and if its short no problem what so ever but if its a long light engine sputers like outa gas and shuts off.Restarts without a problem. If put in N it runs fine and then shift into D and goes runs fine. Just got this truck and workin out the kinks as everything else seems great. Looking for vacum leaks but no luck so far. Anyone have ideas for this one as well. Thanks
better just have to run the ac
Just replaced egr and cleaned all sensors in the air intake with elctrical cleaner and cleaned the intake tube itself with soap and water (ruber part) while there cleaned the conctions with elctrical cleaner ,blew out air filter and all has smothed out and runs great with ac on but still gets realy bummpy without ac on at long stop. Good thing it june in Fla.
Open for ideas on how to get it right.
I owe, I owe off to work i go for another week.
