I6 distributor help
First time I have had to work on motor. 96 F150 2wd. 185,xxxmiles. I was replacing distributor cap/rotor and the screw broke that holds the cap on. Plus I am replacing gasket on side plate. I am trying to remove the distributor and have become stuck. I got the "clip" off but it will still not pull out. Is there a pin or allen bolt stillholding it? I noticed a hole below distributor housing on the block but was not able to get an allen wrench in it?? Please help, truck is dead without help and need truck tomorrow.:eek:
Thanks |
got the distributor out, just needed a little tug. Now on to moving coil out of way to get side plate off.
