Vacuum gauge?
Old Feb 13, 2010 | 09:02 PM
Raptor05121's Avatar
Vacuum gauge?
Is it possible to install one on these trucks? I was thinking about getting an A-pillar gauge pod w/ oil temp, vacuum, and maybe oil pressure.
Old Feb 13, 2010 | 09:18 PM
SSCULLY's Avatar
Sure, any vacuum source in the engine compartment would work for it.
Just T into it, and the vacuum gauge might come with 1/8" diameter white tubing, so the adapter they ( should ) send with it will reduce the engine vacuum line to the gauge size.
Had one on my '01 for a bit of time, cut it into the right hand U shaped piece around the steering column. If you line it up, the gauge will fit in around the metal backing, and lay flat.
Old Feb 13, 2010 | 09:28 PM
Cool, thanks. My sis has one in her turbo'd car (boost/vac) and I think it looks cool when it moves
Old Feb 13, 2010 | 11:47 PM
lol
I have my Scangauge set to hpr, rpm, map, and maf temp... when they look at my map and it says 10 psi they think my truck has f/i... lol
Old Feb 14, 2010 | 04:42 AM
my OBS doesnt show MAP
Old Feb 14, 2010 | 08:28 AM
weird...
i want to know my fuel pressure and oil pressure... and a pyrometer...
