bank 2 lean, bank 2 rich, and misfire... HELP!!
Old Jul 1, 2009 | 08:49 PM
baxternick's Avatar
I have had a check engine light on and off for the past year. Always was a bank 2 code for to rich, or to lean. The engine would hickup somtimes at stop lights, and when under a good load like pulling trailer. Now the truck misfires all the time during acceleration. Usually between 1500-2000 rpms. The truck has a new coil, plugs, and plug wires in the last year, and also new cats. It is a 97 f150 with the 4.2l. I also notice some spark knock every once in a while when under heavy load. With the plug change I used platinum plugs. Everyone said they are crap and pull them so I did and got the basic autolite plugs that were like $3.00 each. The problem did not change a bit with that change. The only thing I can think of is maybe an O2 sensor is shot. Any help would be awesome! Thanks in advance!
Old Jul 2, 2009 | 01:15 AM
Is it using coolant?
Old Jul 2, 2009 | 09:35 AM
baxternick's Avatar
no coolant is staying at a steady level.
Old Jul 2, 2009 | 05:52 PM
Raptor05121's Avatar
so you have autolite plugs in there now? I would go back to Motorcraft. Sounds like an issue mine had a while back, same symptoms and everything- but new plugs solved it.
did you set the gap @ 0.054"?
Old Jul 2, 2009 | 10:50 PM
McLovin's Avatar
Raptor, isn't it past your bed time?
Old Jul 17, 2009 | 02:06 PM
jamesmarshall's Avatar
Thumbs up
hello baxternick. where you able to fix your engine problem? my truck too has the same symptoms and is running horribly.
