| BlueOvalFitter |
Dec 15, 2004 12:06 AM |
First of all you dont need to replace the differential oil unless you choose to.Wal-Mart sells 75W140 synthetic oil for about $9.00 a quart,and is some very good oil.You might want to get one quart to top off the differential.
To replace the seal,first,raise the rear axle,remove the tires,and support the axle on jack stands.Mark the orientation of the driveshaft with the pinion flange.Remove the driveshaft.Take a torque wrench and check how much torque in inch pounds it takes to rotate the pinion shaft.Record this for later use.Count the threads exposed past the pinion nut and record for later use.Put alignment marks on the pinion shaft,nut,and flange.Use a screwdriver thru one of the pinion holes to hold it as you remove the pinion nut.If the pinion flange wont slide out you will need a puller to remove it.DO NOT HAMMER OR PRY ON THE FLANGE! Pry out the old seal.Lube the outer edge of the new seal with grease and use a large socket or seal install tool and tap it in squarely until it seats properly.Re-install the flange,marks lined up from earlier.Use the nut and washer to pull the flange in,if needed.Apply some non-hardening sealant to the pinion splines in the center of the flange so the oil will be sealed in.Install the washer and nut and tighten until the exposed threads are what you recorded earlier.Measure the torque required to rotate the pinion until it matches what you recorded earlier.Then,tighten the nut just a bit more,not to exceed 5 inch pounds.Re-install the driveshaft.Top off any lost fluid.Put the tires back on,lower it and test drive. :santa:
