f150 mass air sensor
Old Dec 9, 2004 | 03:14 PM
krystov10's Avatar
Anyone else have trouble w/ the mass air flow sensor? I had to replace mine, ($400.00); the tech. said my air filter had come apart and some had been sucked in. He also said it may have damaged the seals; and my check engine light came on this morning, (there goes the seals). Ford said new seals will cost $600 - $800! Anyone heard of this problem?
-chris
Old Dec 9, 2004 | 06:25 PM
BlueOvalFitter's Avatar
What seals,the valve seals?
Old Dec 9, 2004 | 09:40 PM
projectSHO89's Avatar
Sounds like BS unless there are other details you haven't given us.
Steve
Old Dec 10, 2004 | 01:38 AM
Kelly's Avatar
Get the code read and figure out what the code means by searching here or https://www.obd-codes.com
Old Dec 10, 2004 | 01:32 PM
krystov10's Avatar
they said they'll have to replace the intake manifold seals. the service tech recommended i buy ford oem air filters from now on ($30/each!). funny thing is, the whole time, the engine has been running fine, no hesitation, no overrev, no excessive exhaust??????
Old Dec 10, 2004 | 05:44 PM
Did they also tell you your blinker fluid needs to be changed? Or,your muffler bearings need to be re-packed? How about the tail pipe being too short and they can use there pipe stretcher to fix it? I strongly suggest finding another Ford dealer to go to.
Old Dec 10, 2004 | 11:03 PM
Tex54's Avatar
HaHa
