flashing check engine light/running poorly.
Old Nov 10, 2004 | 07:02 PM
creech's Avatar
So i've got this '98 F150 with a 4.2 l V6 rebuild with about 50k on it. It seemes to be running on less than 6 cylinders, running really rough and having very little power. i tried some of the tricks mentioned around these boards such as removing a plug wire from one cylinder at a time to see if anything changes.
Removing the front passanger cylinder wire seemed to have no effect (or make things worse) so I'm assuming that's the problem. I removed the wire from the coil pack end, not the plug itself and it seemed to send a large spark from the coil to the wire if I held it 1-2 inches above the coil. From that I assume the coils are good. Do plug wires and plugs go bad after 50k?
Old Nov 11, 2004 | 08:32 AM
projectSHO89's Avatar
Plugs, like any other part, can fail at any time.
If you read your codes (requires a scanner), you will know what the computer is having problems with.
That said, a spark plug costs 4 bucks.
Steve
Old Nov 19, 2004 | 04:41 PM
sacto150's Avatar
I had a similar experience several times with my 94 Ranger, travelling at speed (sorta high) with slight load. With that vehicle I was able to pull over, let it set for a few minutes (sometimes longer) and everything would be fine. I later learned that this had to do with one of the sensors getting out of whack, and turning off the engine let everything re-set.
That's what worked for me. Crazy scary feeling, truck just sort of halfway shutting down while travelling around 75 MPH, yet not actually stalling! WEIRD
Old Nov 19, 2004 | 08:41 PM
stengun's Avatar
Howdy,
Your light is flashing because it is miss firing. You need new plugs.
Paul
