fuel mileage
Old Oct 5, 2003 | 06:18 AM
  #31
BlueOvalFitter's Avatar
Thats how I figure mine Aj.
Old Oct 5, 2003 | 10:15 AM
  #32
B-Man's Avatar
Cool
Originally posted by F150Y2K
I've never replaced my Fuel Filter on my 2000. Every when should the fuel filter be replaced?
BTW, getting like 12-13MPG
Every 15,000 miles or so...
Way cheaper insurance than cleaning clogged injectors.
Old Oct 5, 2003 | 10:57 AM
  #33
wetanner's Avatar
I have a 2000 scab 4x4 orp, auto, with 5.4. I drive off road alot and get 11-12 mpg. highway 15 mpg. +
Old Oct 6, 2003 | 12:09 PM
  #34
MrTrendy1's Avatar
Originally posted by AjRagno
I really have to question how some of you are getting these numbers. If you have a 25 gallon tank and drive 450 miles before you have to fill up, dividing 450 by 25 is not an accurate equation. You need to know how many gallons of fuel you had to begin with and how much you used in X amount of miles.
To have an accurate number, you need to begin with a full tank and reset your trip odometer. Then, at your next fill up, notice how many gallons are required to refill your tank and divide your mileage traveled by the amount of gallons used. What's really amusing is that the formula is printed in your owner's manual
Example: Last week, starting with a full tank, I traveled 158.8 miles. Today, it required 9.57 gallons of fuel to refill my fuel tank.
158.8/9.57=16.59 MPG
Generally when I figure out my milage what I do is write down how many miles I've driven and then when I fill my truck up, use the number of gallons I put in. So my math is pretty dang accurate instead of just saying, 450/25. Typically I get around 365 miles on 23 gallons, give or take a few numbers.
Old Oct 8, 2003 | 01:26 PM
  #35
Tenstar's Avatar
I have a 4.6L V8 2WD, and I get about 17 MPG, with about 75% highway driving And I usually put about 22 gallons in when it is about halfway between 1/4 tank and empty. Thus, I guess I DO have a 25.0 gallon tank
Old Oct 10, 2003 | 06:47 PM
  #36
St Louis Lightning's Avatar
Truck bought Sept 27th. 4.2L Regular Cab 4x2
2nd tank 16.6 MPG
3rd tank 17.3 MPG
4th tank 18.1 MPG
Lets just hope it keeps getting better and better
-Mark
Old Oct 23, 2003 | 05:12 PM
  #37
AlmostRice's Avatar
My trip from San Jose to Houston
map of the trip
_ miles _ gal _ mpg _ mph
1 365.6 16.88 21.65 70-75___LA
2 432.7 20.20 21.42 70-75___Casa Grande AZ
3 355.9 15.66 22.72 70-75___Anthony TX
4 138.8 05.85 23.72 65-70___Van Horn TX
5 452.5 20.45 22.12 70-75___Austin Tx
6 180.2 10.55 17.08 80______Houston TX
t 1925.7 89.59 21.49
As you can see. The mileage got worse over 75 mph. and a little better under 70. after the 2nd & 4th stops 22.72 & 22.12 mpg shows the affect of non-California gas on the fuel mileage when compared to stops 1 and 2 was California Gas.
My best mileage was going through El Paso @ 65mph. Its shown in stop 4. I was expecting only 19 mpg during this trip so an avg of 21.49 was excellent. Also I had a 1000LB load in the bed covered with a blue tarp.
I hope this info helps people on a road trip.
Old Oct 23, 2003 | 05:23 PM
  #38
MrTrendy1's Avatar
I had a similar trip, not near as long as you just showed but I went from Henderson, TX all the way to Charlotte, NC. I know my milage was probably around 18 on average. My average speed was, oh I'd say........ 80-85. Sometimes I'd hit my limit of about 97.
Old Oct 23, 2003 | 06:06 PM
  #39
AlmostRice's Avatar
one more thing
I forgot that my tire pressure was also set to 38lb front and back.
I had 32lb before the trip.
