I just wanna go faster!
Old Feb 13, 2003 | 11:33 PM
  #46
BROTHERDAVE's Avatar
25 Year Member
BROTHERDAVE my best time was 13.76 in the 1/4 mile.
i dont doubt it, g-tech or at a track?
talley said had problems with traction, did you have to do suspesion work to get there.
Old Feb 13, 2003 | 11:49 PM
  #47
XanMan's Avatar
BROTHERDAVE,
at the track and I also had a G-tech that I made runs with almost every day that were pretty consistant.The key is to make each run the same(same flat strip of road, same location on dash,ect.).I had no real problems with traction, being a 4 wheel drive and at the time 3:55 in the rear end. I just eased into the throttle. I did manage to go through 6 sets of tires in about 40 thousand miles.
Old Feb 14, 2003 | 11:33 PM
  #48
RED 92's Avatar
Originally posted by Peacemaker
A Superchip, air intake, and pulley will give you about 30-35 more hp. The chip alone will net you 25 hp. If your looking for a little more get up and go, I say go with a Superchip!
I agree..... I have a filter mod & chip also, I wont name the brand.
Old Feb 15, 2003 | 07:02 AM
  #49
LeanNCut's Avatar
I won't name the brand lmao!
vBulletin Message
Sorry! The administrator has specified that users can only post one message every 60 seconds.
Old Feb 15, 2003 | 11:54 AM
  #50
03F15054FX4's Avatar
231hp 4.6l
205hp 4.2l
26hp difference
Originally posted by 01 XLT Sport
Why do some people think the 4.2 is some weak POS. I have no problem with mine and yes it does haul some @@s for a V-6. As a matter of fact it is basically as fast as the 4.6 (V-8) I have beat 2 01 4.6's where I work. I didn't blow them away as a Lighting would, but I beat them by a good truck lengh or two.
If Talley were here he would know. That guy knew his sh*t and knew it well. I am sure there is someone here that knows the hp and torque diffenence between the 4.2 and 4.6. I believe the horsepower is only 10 - 20hp difference between the two.
Since I have a 5-speed (more hp to the rear wheels then with an auto) and the 4.6's both had autos (lose of hp to rear wheels compared to a manual) the hp and torque must have been pretty equal thus not making it very hard to beat them.
For the ones that insist that the 4.2 just sucks and has no ***** it is because you must not know how to drive it or have an automatic trans. That or you have a manual and dont know how to drive that bad boy the way your suppose to.
NOTE: If you put a superchip in a 4.2 it will have more hp and torque then a stock 4.6.
