Shift RPM?
Old May 11, 2001 | 11:17 PM
Flats Man's Avatar
Cool Shift RPM?
What is your RPM, Chipped and unchipped,
for the 1-2, 2-3 shjift points at WOT?
"The Beast" 98 White 4.6 Triton STX (It's not an STX anymore) Flareside,Class III hitch.
Appearance Mods: Blue Cobra Stripes, Euro Lid by Astro, Bed Rug, Fiero Wing, Air Dam,Ground Force 2-4 Drop,Custom MB Phantom Wheels,clear corner lenses,monster battery terminals, Custom Ford Racing, Leather Seats.
Stereo Mods: MTX Dual Sub Box with 2 10 inch Polks, 4 Polk Speakers, MTX 102 Amp with a Pioneer FH-P4400 CD, Cassette Head Unit
Performance Mods: 96 Crown Victoria Electric Fan Mod, Custom Programmed Super Chip,BBK 75mm TB, Pro M 80mm MAF,Custom Welded Powder Coated Intake Tube,Pillar Pod w/ boost and trans temp,Jacobs DIS Ignition,Art Carr 2400 Stall Performance Transmission,4:10 gears with Auburn Pro Limited Slip,TA Performance Rear End Girdle, Cal Trac Traction Bars, Jet coated JBA stainless headers, custom Y pipe after the Cats, Magna Flow Muffler with Stainless Duals and of course fully Blown by Magnacharger!
Best 1/4 so far 15.117 @ 89.05
Best 60' 2.137
http://www.zing.com/album/?id=4293450711
[This message has been edited by Flats Man (edited 05-11-2001).]
Old May 12, 2001 | 06:05 PM
evo's Avatar
evo
Post
Hi, My shift point with a superchip is 4500 RPM at WOT 1st to 2nd.I haven't noticed between 3rd & 4th. I like the look of your truck. What kind of lowering kit did you put in it? And did it affect the clearance on your exhaust.
[This message has been edited by evo (edited 05-12-2001).]
Old May 12, 2001 | 10:43 PM
Flats Man's Avatar
Cool
Thanks for the response EVO! My truck has a Ground Force 2-4 drop. I did the exhaust after the drop. My super chip is running up to 5200 in first and shifting from 2nd at 4500, like yours. It puts me in 3rd at around 65 mph and 3500 rpm. I think that is killing my ET because I am accelerating in third at low rpm the last 1/8 mile. Super chip is working on a flip chip for me right now which should take care of that. I just wanted to know if it is normal to shift out of 2nd at 4500. Thanks!
Old May 13, 2001 | 05:46 AM
evo's Avatar
evo
Post
Hi Flats Man, Glad I could help. And thanks for answering my ?'s. I'm putting a Kenne Bell on(in) next week. I think I'll need more traction. My question is about your Caltracs( cheapest price +). Do you have to run them preloaded all the time and does this have any detrimental effects to the suspension? Because I thought they were a strip only traction bar. Also what size tires are you running? I already put my new borla exhaust on (dual out back) do you think I'll have clearance problems? It looked like I had aleast 5 or 6 inches over the rear axle.
Old May 13, 2001 | 07:06 AM
Chucky Tucky's Avatar
Post
Those RPM shifts sound a little low. My shifts with a superchip are all at 5200 rpm. Actually the 5200 rpm shift from 2nd to 3rd is to high. You can feel it running out of its peak power band at about 4900. In my opinion, the shift points should be lowered a little.
2001 Screw, 4x4, 5.4L, 3.55LS, trailer tow III, 255-16 tires, skids.
Superchip
Gibson Stainless SS
AirRaid FIPK
Century Cap
Line X, other misc.
Old May 13, 2001 | 02:48 PM
crazyaboutF150's Avatar
Post
Hi Flats Man,
With the stock ECU program, my 1-2 and 2-3 shifts were around 4500 rpms. With my custom (flip-chip) Superchip, I asked for a 1-2 shift @ 5600 rpms and the 2-3 shift @ 5400 rpms.
With my modifications, I pulling great up and making power up to those shift points. My little 4.6 runs pretty dog gone good!
'00 F150 SC w/ 4.6L, Oxford white, Gray Int., leather steering wheel, white faced guages, factory fender lip moldings, GTS slotted tailight covers (painted Oxford White), white front grille/headlight assembly and front bumper cap (painted Oxford White), lower factory valance w/ driving lights, "Lightning/SC" decals, Ford billit hitch cover, Line-X-bed, carbon fiber hood/ bug deflector.
Performance: 75mm BBK throttle body, Poweraid spacer, Granatelli 80mm MAS, K&N Generation II intake system, ASP pulleys, 2-16" Hayden Rapid Cool electric fans, Gibson headers, Magnaflow cat-back exhaust (split rear), Baumann Engineering shift kit (set on Stage 4), B&M Stacked Transmission Cooler, 3:73 rear gears, custom (flip chip) Superchip.
Future mods.: 2/4 drop kit, Lightening 18x9.5 chrome wheels, 295/18 Z rated tires, fiberglass tonneau cover, Stillen front bumper cover, Powerdyne SVO supercharger, JBA ceramic coated headers
Old May 13, 2001 | 04:02 PM
Flats Man's Avatar
Cool
Hi CrazyaboutF150,
Thanks for the info! Right now I am planning on 5400 for both 2nd and 3rd gears. It looks like your are setting yourself up real well for your blower. I will be going to a smaller blower pulley so I may elect to leave the RPM at 5200 so I don't over spool the blower. I am talking to Mike T tomorrow and will do what ever he suggests. Have you run your truck in the 1/4? I think it would do well.
Old May 14, 2001 | 12:22 AM
Flats Man's Avatar
Cool
EVO, The Cal Tracs are absolutely necessary with my truck if I launch at full throttle. Before< I was getting bad axle wrap and wheel hop. So bad that I had to come off the gas to end it. They are slightly preloaded which is perfect for my truck. I got the Low Profile model that is very hard to see from the street. I can launch this truck with my hands off the wheel it is so straight.
Chucky Tucky- I pulled the last dyno chart on my truck and I am still making HP through 5400 RPM which is where the rev limiter shuts me down. This blower likes RPM so I think I will be fine with the limit set at 5200 or maybe even 5400.
Old May 16, 2001 | 08:46 AM
Flats Man's Avatar
Cool
Just a last update. I ordered a flip chip from Mike T. with a 5200 rpm limit on the street/trailer towing side and a 1/4 mile side that is more aggressive with a 5400 rpm limit. I will do another dyno for rear wheel HP and F/A ratio and post the results.
Old May 17, 2001 | 05:45 AM
evo's Avatar
evo
Question
Hi Flats Man, Do you know at what RPM your fuel shut off kicks in? Does the chip take care of that? The 2001 L's shut off at 5400. Thanks in advance, Evo
Old May 21, 2001 | 05:10 PM
Flats Man's Avatar
Cool
Hi EVO-sorry it took so long to get you a response. My fuel cut-off is also at 5400 rpm but will be raised to 5600 with the chip if I am understanding things right. When I do the next dyno after the new chip, I will let you know.
Old May 21, 2001 | 08:05 PM
Neal's Avatar
Cool
HI!... FLATSMAN : My custom SUPERCHIP makes the 1ST to 2ND shift at 5800rpm and my rev limiter was raised to 6000RPM. My 2ND to 3RD shift is at 5400RPM and the rev limiter was raised to 5800RPM. My truck pulls really hard up to 5800RPM in 1ST gear and my power does'nt FALL OFF at all.
FLATSMAN : When you are at the dragstrip, do what I learned to do for the best times when I had my old SUPERCHIP in. Leave the starting line with the truck in drive. As soon as the tranny shifts into 2ND gear pull the gear shifter into 2ND gear. Hold it there until your RPM's hit 5100RPM and then shift it into 3RD gear. My truck goes about 3 tenths slower when I let the tranny shift it'self. Hope this helps you out.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, PERMA-COOL external tranny filter, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.52E.T * MPH - 93.73 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
Old May 21, 2001 | 08:26 PM
Flats Man's Avatar
Cool
Thanks for the tips Neal. I have ordered the chip from Mike T. and I will be happy with the new rev limits for now. I ran a 15.1 with it shifting out of 1st at 5200, 2nd at 4500 and dropping into 3rd at 3500 inside an 1/8 mile. My goal is low to mid 14's right now. I will let you know how I do when the new flip chip comes in and I can test & tune it. I will have to look you up sometime. I come up to DTW about twice a month and would like to make it over to SHM one day. I would also like to see your truck! I am still looking for a 4.6L throttle body elbow to port out if you see any.
