tranny question??
On my 99 F-150 5.4L, I have the calss III towing package, does that include the trans cooler and oil cooler?? Also do I have the 4R-70 or the 4R-100 tranny?? whats the diff??
You should have an external trans cooler not sure about the oil cooler though i have a 00 and dont have one. You probably have the 4r70 unless you have the 7700 payload group. the differnece between the two trans is the input tourque they can handle 4r70=700 lb-ft 4r100=1000 lb-ft
00 F150 silver 5.4 auto 4X4 3.55 LS
<font face="Verdana, Arial" size="2">Originally posted by therock:
On my 99 F-150 5.4L, I have the calss III towing package, does that include the trans cooler and oil cooler?? Also do I have the 4R-70 or the 4R-100 tranny?? whats the diff??</font>
Open the hood and look at the lower radiator hose below the coolant reservoir tank. You'll not only see the hose from the tank connecting to the radiator hose, but you'll also see another and this one goes to the oil cooler that's mounted between the oil filter and engine block. You can also look at the oil filter and you'll see the two coolant hoses running to the oil filter mount.
