Refilling Torque Converter
I am going to drain the tranny fluid to switch to synthetic and wondered if someone could tell me if refilling the tranny and torque converter is as simple as pouring the fluid down the dipstick tube? Its the torque converter I'm concerned with. Hopefully I can find the drain plug on it.
There is a drain plug. You are right to use it, just don't overtorque. As for refilling, pour 6 to 8 quarts into the trans dipstick tube and start her up. Let it idle and top it off. Depeding on the trans and how much fliud you get out, it should take around 14 quarts, give or take.
I had to put the rear-end up on jack stands! after about 8qts. of oil I ran it in drive for about a minute to let the converter pump it self up with tranny fluid. I had to do this about four or five times.
1998 F150 Triton 5.4L (4x2)
K&N Air Filter
Pioneer 4100 W/remote
2\10" Rockford Fosgate Punch He. RFP4310
CatBack system with Magnaflow system 3" Pipe
3" Performance Acc. Body lift, with lift lips
Xenon HID Super Whites 9007's
Front Clear Corners
Sonnax Line pressure modulator kit model#AX4N
K&N Air Filter
Front Clear Corners
HI!... REDLINE!
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
