clutch bleeding problem
I had the trans out of my 97 f150 4x4 to do the clutch and install the internally mounted slave cylinder. Now, I can't get the clutch line to bleed out. I disconnected fords little quick connect fitting to see what would come out of there when the pedal was depressed.(With the end of the line pushed in) Not much comes out and the level in the reservoir won't drop at all either. Any suggestions???
1997 f150 4x4
extended cab, xlt
4.6, 5 speed 3.55 gears
1997 f150 4x4
extended cab, xlt
I forgot to say, the pedal never builds up any pressure and the slave cylinder doesn't move at all.
1997 f150 4x4
extended cab, xlt
1997 f150 4x4
extended cab, xlt
