F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Transmissions (https://www.f150online.com/forums/transmissions-25/)
-   -   Slippp...ing Again/what's wrong? (https://www.f150online.com/forums/transmissions/9480-slippp-ing-again-whats-wrong.html)
98SCREAMER Nov 15, 2000 11:18 AM
My trans has been slipping again. Usually happens when the engine is cold. I have to go up a hill when I first leave my current apt. I have to stop at the top of this hill before turning out onto the main road. When I leave from this stop,while turning,it starts off fine. But halfway through turning,the trans slips and then goes back into gear. This also happens when I let off the gas,then reapply,after the truck is warmed up.
I had the fluid flushed,and changed with
Mercon V. It seemed to help for awhile,but now it's started again. Have I hurt the trans,somehow. Both times I've had the fluid changed before the scheduled time,so why could this be happening? I am going to try the slip yoke lube soon,but this feels like the trans. I also have a diff. fluid change scheduled for Fri.,it was alittle dirty when checked the other day. I'm getting worried
that the trans is going bad at 48,000 miles. Let me know of any tricks to possibly fix this,,,,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Euro tails(Altezza style)
Cobra 75WXST cb w/weather alert
Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
Viper 500HF Security system
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order
www.my-f150.com Still want to lift it,YESSS!
FENDER GUITARS,ROCK!!!
http://www.bigsandy.net
officialtomwaits.com
reverendhortonheat.com
WOW,what a cool site!
mpocrats Nov 16, 2000 11:16 AM
Same thing here. Need help! My problem goes like this:
Seems like when the trans shutters out of the hole and from 2-3 and 3-2. Also, if I leave off the gas and coast at 45-50mph and then hit the gas (not enough to downshift into 2nd)it bangs into gear rather hard then shutters. What could this be? I too am baffeled. No codes yet. Had the Bilestien trans flush at 24K now have 32K. Tow a 3500lb boat in the summer. 99 4X4 F250LD SC with 5.4, 3:73, auto.
Any thoughts? Solenoid(s)? Torque Converter? Slip yolk thing? programming?
98SCREAMER Nov 16, 2000 11:48 AM
No shudder here,but this slipping has me worried,bigtime! BTW,on the warmed up
slip, It acts like it's in gear,but not completely. Kind of like something is holding it back,then it clunks into to gear.
I am noticing it has something to do with
the OD button,acts wierder when it's not turned off,or when I forget to turn it off,,,98
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Superchips_Distributor Nov 16, 2000 01:04 PM
Screamer,
That sounds like you could have shift solenoid problems. Unfortunately, a lot of Ford dealership service departments aren't very good at diagnosing shift solenoid failures/problems.
If it feels like it's slipping into neutral for second and then going into gear, it could very well be the shift solenoids. Luckily, they're pretty cheap, and easy to replace, the attach to the valvebody.
Good luck!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
98SCREAMER Nov 16, 2000 02:35 PM
I guess that's it,then. How many are there,and how much do they average?
I think it'll be okay,since your not actually
selling me the parts in question,eh,,,,
I hope it doesn't hurt anything,since I might not be able to do it til after this weekend. Life on the road pays well,but doesn't leave you much time to get anything done: (
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
on the front end.Billet grilles on order www.my-f150.com Still want to lift it,YESSS!
[This message has been edited by 98SCREAMER (edited 11-16-2000).]
conway Nov 28, 2000 11:50 AM
Also sounds like my problem. Let off the gas at 45-55 or so, let it slow down a little, and then gently punch it again and it hesitates like it is out of gear. You can fill it slip back in.
How much, how many, can I swith them out, etc.? Thanks in advance!
97 F-150 XLT 4x4 SuperCab
98SCREAMER Nov 29, 2000 12:16 AM
Oh Mike?
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
[b]Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good]
conway Dec 6, 2000 02:49 PM
hello? https://www.f150online.com/f150board/smile.gif
98SCREAMER Dec 6, 2000 04:08 PM
on vacation? lol
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Euro style tail lights
Viper 500HF Security system.
Come see my new picturesat www.my-f150.com
FENDER GUITARS ROCK!!!
98SCREAMER Dec 6, 2000 04:43 PM
Well the Ford dealer here Ft. Lauderdale seems to think there is only one on the 4R70W? they weren't sure. They quoted
me a price of $31 and change,if it's one,that is reasonable. But if it takes 3 or 4 of them,it could get expensive. My Chilton manual only has changing the fluid,in the trans section. Who are the people who write them,and why don't they have any other info for the trans?,,,,,98
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Wichita_Greg Dec 6, 2000 05:05 PM
If you want to see good instructions on the 4r70w transmission (that's what most f150 have), go to the Thunderbird site:
http://www.tccoa.com
Rebuild, repair, improvements.
You only need one.
There are lots of TSB's out there on this tranny, I've seen your problem in one of them, but can't find it.
Greg
'96 Triumph Thunderbird
'99 Ford F150 XLT SC 5.4
'00 Lincoln LS8
Wichita
98SCREAMER Dec 6, 2000 05:27 PM
Hey Thanks Wichita Greg,
This was a major help to me and conway
both. Now,if this solves our trouble,It would be too cool. Mine was fine one day,then the next it was jumping out of gear on hills,and slipping the next.,,,,,98
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
conway Dec 8, 2000 03:09 PM
Yeah, thanks.
98,
If you get any where let me know. I will post anything I find out too. This is the only thing that has disappointed me so far about this truck.
98SCREAMER Dec 8, 2000 06:55 PM
Same here.,,,,98
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
