OK, I know from experience that the valve body kits work. I thought I'd try something new. I see several good points to the B&M shift Plus.
1. easy to install, no need to drop the pan.
2. switchable performance off-firm-firmer
3. it's cheap
Do they really work? I like the fact that I can revert to stock by flipping a switch. I've heard they fry trannies, but I think that's BS. Let me know what you think.
'92 Flareside 351 E4OD
3. it's cheap
Isn't this the same thing a Banks TransCommand and the Superchip do with the shift points?
A steal at $35
1999 F250 SD CC, LWB, 5.4L, Auto, 3.73, 4x4, Power TT mirrors w/ marker lights, White, Full Tint, PendaPro SR, Flowmaster Delta 40 series, K&N filtercharger, Superchip (Airbox removed for a second try, maybe in the winter it will be advantagous?) Lund Elite soft tonneau
www.angelfire.com/pa3/spaceace/index.html
A steal at $35
Well I'm changing my axle gear ratio from 3.08 to 4.56! A definate requirement for the 33" tires I'm running. I have a feeling the trans may shift a little differently with the lower gears. If it still seems mushy after the gear change, I think I'll try the B&M unit. Thanks for the info everybody.
Rockcrawl,
I am getting ready to do the same thing, is yours finished yet?
98 F-150 4X4 Ext Cab ORP 4.6L Superchip, Gibson Cat Back Single exit exhaust, TransGo Performance Shift Kit, K&N Filter. Future: 4.56 gear swap, shorty headers.
JET also makes a plug in tranny module that is more expensive than the B&M unit and has more settings I believe. I have seen it in the Summit Racing catalog. Any one have any experience with these either?
