Slip?
Old Jul 24, 2002 | 11:27 AM
TomatoTruck's Avatar
Slip?
I have a 98 with a 4.6L and the 4R70W tranny. The other day I noticed that I will be cruising down the interstate at about 70 mph and the tranny will down shift and the RPM's will hit about 3 and 1/2 for about two seconds and then drop about 400 RPMs and then kick back up. It is still pulling right and I do not think that it is changing gears what is it. I feel the actual shift at about 80 mph. What is this RPM drop?
Old Jul 24, 2002 | 11:36 AM
TroyK's Avatar
Re: Slip?
you need to be more specific about what you are talking about...but it sounds like the torque converter clutch unlocking/locking. this will cause rpm fluctuations...completely normal, or at least from what i can glean from your limited info.
Old Jul 24, 2002 | 02:34 PM
Information?
Not to sound like a smart @ss but I thought I gave very clear information. What more information can I put. I will try this way. At 70 mph and I hit the passing gear the RPMS will raise from 2000 RPMS to 3500 RPMS with the throttle in the same position the RPMS will lower 400-500rpms and then raise back up to about 3900RPMS and then shift gears. I have an extended warranty on this transmission but I wanted to know if this was normal or not. Believe it or not some dealer will lie to people about problems
Old Jul 24, 2002 | 09:00 PM
Mark Kovalsky's Avatar
That's normal.
When you step on the throttle the transmission will downshift from fourth to third, and the torque converter will unlock. After a few seconds the torque converter will relock. That's the 400-500 RPM drop. Then the transmission will shift back to fourth gear.
Mark
Old Jul 25, 2002 | 10:01 AM
Thanks for the information. Reading this sight about my tranny has me worried
