Transmission fluid for 2010 stx
Old 07-12-2019, 10:22 PM
eezy_93's Avatar
I’ve always had Chevy trucks. Clueless with ford. I just got a 2010 STX 4x4 4.6l. I noticed when checking fluid while hot and running, the level is in between the two dots. I’ve read there is stuff out there that can ruin your tranny. What should I use? It also has 97k. Any other preventative maintenance I should take maybe?
Old 07-12-2019, 10:41 PM
Instead of adding fluid, with those miles, I would take it in for a transmission flush. I would get the cooling system flushed as well.
Old 07-12-2019, 11:20 PM
glc is offline
In between the 2 dots is the correct indication. Nothing needs to be added. The correct spec fluid is Mercon LV.
Old 07-13-2019, 08:37 AM
Typically the transmission doesn't use oil... or consume it, or eat it... whatever you want to call it.
If you are losing oil, it's because of a leak.
Other than that, it sounds like you have no issues if the level is between those two dots.
Quick Reply: Transmission fluid for 2010 stx
