Help m5odr2 trans swap
Old 10-07-2018, 01:50 PM
Fl280078's Avatar
I have a 1988 Ford F150 custom 5.0 5 speed I was wondering if I could take a m5od R2 out of a 1997 F-150 with a 4.6 and just bolt it in? my transmission is starting to act up and not want to go in or come out of gear my clutch is good but I believe it is the throwout bearing that is going out and plus in every gear except 4th and reverse there is bad grinding noises and whirling noises can I do a direct swap without having to change anything please help.
Old 10-07-2018, 03:03 PM
glc is offline
Please don't post all over the forums, and please don't send private messages asking what you have already asked in the forum. Thank you.
Short answer: Nope, not compatible.
You can use a M5OD out of a 300 I6, 302 V8, or 4.2 V6. These all have the Windsor bolt pattern. The 4.6 uses a different pattern. It also has to be out of the same drive system (2wd or 4wd). I also believe a 99 or newer will require mods to the floor, the shift tower was moved.
If it's the throwout bearing going out, a trans swap won't fix that, you need to rebuild the clutch. You also might have a stuck pilot bearing.
Old 10-07-2018, 03:08 PM
Fl280078's Avatar
Thank you for you time i appreciate it
Thank you
Quick Reply: Help m5odr2 trans swap
