Please help me diagnose Tranny problem
2002 4.6L 2WD
Last night I was on the freeway doing about 70 and all of a sudden my rpms shot up to 4K+ and my overdrive light came on. Truck currently won’t shift past second gear about 40 mph at 3k rpms. I had no problems with the Tranny before hand, no weird noises, etc. Can anyone give me advice? Buy a new Tranny? Etc?
might try ideal
Try taking the negative cable off the battery and be sure to isolate it by wrapping a shop towel or something around it so it cannot hit or touch the neg post then take a jumper wire with alligator clips from the pos post to the engine block that will drain out lots of things but when you reconnect everything after a half hour it will learn a shift pattern again. Worth a try and it worked for me.
