2001 2wd 5.4 transmission issues
Ive got a 2001 f150 2wd triton 5.4 model with transmission issues and im not sure what tranny is in it. I may have found a 2002 parts truck with a good tranny in it but not sure if its the same or not. I just bought the truck 2 weeks ago for my son so i know nothing about the truck. So my question is What transmission is in my truck and what all is a compatible with it?
It's most likely a 4R70W. What's the TRANS code on the door jamb sticker? "U" is 4R70W, "E" is 4R100.
If it's a 4R70W, any 4R70W out of a 4.6 or 5.4 2wd F-150 from 1999-2003 will bolt right in. However, for best operation, you need a 5.4 torque converter. If it happens to be a 4R100 (not likely at all) I'm not sure what will fit - I think a 99-01 4R100 out of a 5.4 2wd F-150 7700.
Here's a pic of the pan gaskets for Ford automatics, you can tell the difference between a 4R70W and a 4R100 by pan shape.
http://www.crankshaftcoalition.com/w...OD_gaskets.gif
