Transmission problem s
I have a 99 f-150 4x4 with a 4.6l motor what makes and models r capable with my truck
99-03 4R70W out of a F150 4x4 with 4.6 or 5.4.
Thank u so very much for ur advise
Will a transmission from a 99 expedition fit in my 99 f-150 both r 4x4
If it's a 4R70W it should, but not if it's a E4OD/4R100.
Thank u very much for ur advice
Will a transmission from a 2006 f-150 5.4l 4x4 fit my 99 f-150 4.6 4x4
The sun gear failed in mine, it is supposed to be a common prob. Rest of the trans was mint but it still cost me a full rebuild, including a "new" torque converter that was not needed.
It does not lock up as smooth as the original unit. For $1500, I should have explored a gently used unit? |
Originally Posted by Bobgullett
(Post 5228973)
Originally Posted by IH man
(Post 5228974)
Yup, Mark is right. Too many crevices for metal and dirt to hide. Might as well do it right the first time.
Same goes for manual transmissions -- if you are going to be replacing the friction material, you might as well go for either a new flywheel or get the old one turned. If you don't, you'll have issues later on down the line. Ain't no fun doing the job twice. |
Same goes for manual transmissions -- if you are going to be replacing the friction material, you might as well go for either a new flywheel or get the old one turned. If you don't, you'll have issues later on down the line. |
Will transmissions from expedition or explorers work in my 99 f-150 4x4 with a 4.6l motor
No on the Explorers. Some of the Expeditions
You need to find a 4R70W out of a 99-03 4x4 F150 or Expedition with a 4.6 or 5.4. Can we get any clearer than that?
