2005 f150 stx No drive only reverse.
I was driving just fine then lost drive power like the gears weren’t engaged. The transmission, overdrive, and wrench light all came on. Got it towed home and figured out reverse works just fine. When in park it revs just fine. Trans fluid isn’t burnt or low. Friend that diagnosed it said it was the throttle body actuator/motor. Changed the part out and still the same problem. Curious to see if anyone is or has experienced the same problem. Any help would be great. Thank you.
