2005 F150 Major Transmission issues.
Old 09-14-2017, 11:44 AM
FoMoCo4life's Avatar
Hey Everyone very new to this forum but need some guidance.
I Just bought a 2005 f150, the trans was doing the slip in over drive so last night i dropped the pan and valve and replaced a broken retainer ring hoping that would be the fix. Dug all the pieces out of valve body put new ring in, put everything back together added 5 quarts of fluid start it and when I shift in to reverse it backs up but if I shift in to any other gear the rpms have to be way up for me to be able to crawl forward then I got a trans fault and O/D flash.
What Did I DO?
Old 09-14-2017, 12:57 PM
glc is offline
Scan for OBD2 codes with a scanner that can read Ford transmission codes.
Old 09-14-2017, 08:53 PM
The Codes I received are P0720 P1000 P0722 P2106
Old 09-14-2017, 09:06 PM
glc is offline
Old 09-14-2017, 09:34 PM
Would make it not drive at all?
Old 09-14-2017, 11:17 PM
glc is offline
It's possible. Read all 3 of those links.
Old 09-17-2017, 10:28 PM
Mark Kovalsky's Avatar
I'll bet the manual valve isn't properly connected to the shift linkage. This will set a false OSS code.
Old 09-19-2017, 09:55 AM
Darrin Burch's Avatar
Yes, this
http://www.bcawebstore.com/leverslot.jpg
