Trans swap 06 4r75e in place of 02 4r70w
The problem you are going to have is that the output shaft sensor count is different between the transmissions. There is no way to fix this short of swapping the output shaft ring gear or reprogramming the vehicle computer.
Swapping the ring gear requires total tear down of the transmission as it's the last thing all the way back in the case.
D
D
