4R75W Torque for valve body, oil pan and pump.
I'm looking for the torque on these 3 items. I searched a bit on the internet but they don't seem to have a clear answer. I've seen around 14nm (10.3 lb-ft) but it was for a different transmission. I'm not sure if it's compatible.
Thank you. |
straight from the factory service manual.
oil pump to case bolts 16 ft lbs. valve body to case bolts 100 inch pounds oil pan bolts 130 inch pounds |
